Creating a wall style with solid fill in fine detail level
vanderloo5
vanderloo5
I've posted this before and the answers posted involved selecting certain walls in a floor plan and applying graphic display changes.
That works. But I need a wall style that is solid filled when added to the drawing, (in detail level fine).
I do a lot of remodel/addition plans and I show existing walls unshaded and new walls with solid fill.
I don't want to have to select all of the new walls and change the graphic display every time.
So, can I have a wall style that has solid fill out of the gate?
Thank You
vitorbortoncello
you can create a material, customize the cut patterns, and assign it to the wall.
Another alternative would be creating a view template where every wall has a specific cut pattern.
See what works best for you
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Create a monolithic wall type with one layer and assign material with a solid fill pattern to that layer.
