Creating a void or opening in stairs
7 ANTWORTEN 7
Nachricht 1 von 8
2815 Aufrufe, 7 Antworten
I'd like to make a diagonal void/opening in this staircase as it is positioned over a building. I have tried to use Generic Model Void and Opening and it will not select the stairs.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Unfortunately I do not think that stairs in Revit can be cutted , by shaft opening nor by any other opening nor by generic model family.
but as a work around ,
 you can create the whole geometry as an inplace family but then it doesn't behave as a stair so changes to levels, addition of a stair part, cut lines etc don't work as they do with other stairs in the project.
you  can also make it as 3 separated stairs beside each other.
I wish I would help,
best Regard,
Rana Hamed
Nachricht 3 von 8
ennujozlagam
@Anonymous hello, it's better to use stair by sketch to control opening rather than using stair by component. thanks
Nachricht 4 von 8
als Antwort auf: ennujozlagam
@ennujozlagam
Hi , how will you create the opening that will cut the stair by sketch?
Nachricht 5 von 8
Kimtaurus
You can create an opening in the staircase by dividing the stair into several runs.
On each side of the opening you place/draw a new run, making sure the relative base height of both runs is the same.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 6 von 8
ennujozlagam
@Anonymous Hello, I didn't say that you can create an opening by using a stair by sketch in my posted suggestion. What I'm trying to say is to avoid the opening when you use a stair by sketch. Thanks
Nachricht 7 von 8
ennujozlagam
@Anonymous hello, my bad. i tried to replicate not possible at all. only solution i can think of is @Kimtaurus suggestion. and still need to use stair by sketch to get irregular shape. thanks.
Nachricht 8 von 8
I was able to create this using a generic model. Thank you.
