Creating a stud walls and openings
jrogerson97WEF
jrogerson97WEF
I am very much a beginner to Revit and am trying to create a basic model of the structural aspects (stud walls, foundation, floors, trusses) of this building (seen below). So far, all I have done is created the layout in plan view using the wall tool and assigned the proper dimensions. I then copied this up for each respective floor. My next goal is to make these walls into stud walls, 2x6 @ 16" OC, just the stud walls and openings, no drywall etc. I have downloaded the content with the dimensional lumber etc. What would be the best way to go about this? Any tips are very much appreciated as I am very new. Thank you.
 *EDIT* this is for a capstone project. I just need an isometric view of the 'skeleton' for a poster. Fine details are not  too important
SteveKStafford
You can place individual families for studs, sill, top plate etc. To help steer you in the correct direction, what are your goals? How will you use the model?
Steve Stafford
HVAC-Novice
There are multiple options and the most popular one is to not model the studs at all.
What is your goal? Will this be a structural model? Do you need to schedule and count all lumber needed? Will this be a detailed design for the carpenters? Will studs be schematic, or do you plan to place each head, cripple and other studs?
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
jrogerson97WEF
Hi Steve,
Thanks for the reply. This is just for a school capstone project. I just want something very simple for the poster, a simple isometric view showing the 'skeleton' of the building.
Joel
jrogerson97WEF
Thanks for the reply. This is just for a capstone project, I need an isometric view of the 'skeleton' of the building for a poster. Details are not too important, lumber count, etc. will not matter.
Joel
SteveKStafford
Okay you're looking at building it "stick by stick" where the sticks are structural families (wood). You could use Curtain Walls where the panels are "empty" and the curtain grid/mullions are the stud framing. You could also create your own generic model families for the different framing components. Using the structural families you'd be using structural columns for vertical framing and structural framing for sill, plate, header etc. for horizontal framing. You''ll have to move back and forth between plan and elevation etc to fine tune everything.
Steve Stafford
jrogerson97WEF
ended up using the curtain grid/mullion technique. Thanks for your help!
