I am having trouble creating a concrete 'crate'that has sloped walls on 3 sides.
1 wall is supposed to be 45 degrees and the other 2 80 degrees.
It takes me forever to get this right, is there a quick way to set walls at a desired angle?
I attached a screenshot to give you an idea of what im trying to do.
The vertical hight of the crate should be 1255 mm and wall thickness 300.
What is the quickest way to create these kinds of walls
