Creating a stepped foundation on a sloped lot
vanderloo5
vanderloo5
What is the best way to create a 6" concrete stemwall with a subterranean footing that matches the slope of a lot. I'm fine with adding my footing profile to the bottom of the wall. But I want the top and bottom of the wall to step with the slope of the toposolid.
Thank You
Create walls stepping down then create wall foundations.
alan.johnson7YLND
I would use the Wall>Edit Profile method.
Draw your section of wall, then edit profile
Edit the magenta profile line to match your topo to add steps
