Creating a statement using parameters in a family
4 ANTWORTEN 4
Nachricht 1 von 5
351 Aufrufe, 4 Antworten
I need to use depth and height parameters from a family to produce a product code for different variations of the same family. For example the text would display the depth and the height followed by the finish of the item:
Product Code = DepthxHeight - Finish
is there anyway to get this to be variable when the size of the item is changed? At the minute I am using 'If(And' statements, but for the amount of variations required this would need a massive formula.
Thanks in advance
4 ANTWORTEN 4
Nachricht 2 von 5
semko_dm
als Antwort auf: Anonymous
Hi!
You can try to combine parameters. This is new tool, that appeared in revit 2017.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Tags (1)
Nachricht 3 von 5
als Antwort auf: semko_dm
Hey,
unfortunately our library and projects work back as far as 2014, so this wouldn't be a solution to the majority of the projects we work on. I also need it to only do this on certain families, not for a full schedule. The product number in question only applies to one range of products. Thank you for your help :leicht_lächelndes_Gesicht:
Nachricht 4 von 5
semko_dm
Well, I think, with Dynamo you can do it pretty simple. Even in revit 2014.
Dmitriy Semko
BIM-Manager
Blog
Nachricht 5 von 5
How would you show the Code in your projects, as a tag? If so, it is fairly simple.
