Creating a stairs with landing
BugFinder
BugFinder
I'm trying to create some stairs with a landing like in the attached dxf.
Obviously I know the height of the first floor and I know I need 16 steps.  Each step is 220 wide and 170 deep.
Firstly, I cannot seem to be able to get revit to create stairs at the specified length of 2947.  Secondly, how do you create landings?  Is there a particular function for this or are they part of the stairs?
Whatever I seem to manage to create is either longer/shorter than 2947 which then raises or lowers the height!!
It looks like the it is possible, given the dimensions in the dxf which seem to add up...
See attached.
Draw a straight run of 16 risers then draw a landing by sketch.
