Creating a Sheet Pile Wall with Adaptive Models
I am trying to create a sheet pile wall that slopes with the topo of the site. I have inserted a sweep into a adaptive generic model. From there I add an Adaptive Point to the sweep. I then took that into another adaptive generic model that has a sloped divided path.
This is where I get stuck. My sweep does not remain vertical (I have it set to remain vertical) and once placed on the path, I can't use the repeat function to have the sweep continue down the path.
I have uploaded the final adaptive model to this that has my sheet pile sweep loaded as a component.
Thanks for your help!
cbcarch
Check this out:
A bit tedious, but it works.
http://therevitcomplex.blogspot.com/search?q=wall+to+follow+topography
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Thanks for the fast reply!
I should add that this wall is to be used for the retaining wall of a ramp going down into underground parking so the top slopes with the topo with a concrete cap and metal guardrail above so that solution isn't exactly what I'm trying to achieve.
I'm hoping that this adaptive model is what will solve my issues but I can't get it to work propoerly. I am using the method that I found HERE but have somewhere missed a step or am doing something wrong.
