Creating a sheet order parameter
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2007 Aufrufe, 3 Antworten
We have sheets from surveyors and whoever else named weird things like "1 of 1" or whatever that we want to include in our plan set in a certain location in the set. I have created a shared parameter called sheet order I was trying to use as an instance parameter to manually reorder the sheets and while I can insert that shared parameter into my schedule... it doesn't populate with values. Does anyone know how to do this? Or have other solutions? Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Create a Project Parameter using the Shared Parameter you created. Assign it to the Sheet Category. Select and Right-Click on Sheets in the Project Browser, then select Browser Organization from the Drop-Down, go to Sheets tab and click on "New"  to create a new Organization Scheme.  Filter, Sort and Group using the Project Parameter you created and added to the Sheet Category
Nachricht 3 von 4
AidanHawkins
als Antwort auf: barthbradley
Can I do this for views also?
Nachricht 4 von 4
RobDraw
als Antwort auf: AidanHawkins
Have you tried it?
Rob
