Greetings,
I was following the instructions for Creating a Roof with Different Eave Heights (Link)
But got trouble with the procedure when joining the two roofs, because you need to pick a line and a surface, and that is not there in the instructions.
How can i do the roof in the link? (Image below)
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von mariano_biagioli. Gehe zur Lösung
Hi, the link in your coment isn´t working.
Are you using the Join/Unjoin Roof tool?
Here is an example to use it with diferent eaves heights
Please, if the answer helped you, mark it as a solution ![]()
your Roof can be done from a single Roof by Footprint.
The result is this:
Constantin Stroescu
and here are the steps:
https://knowledge.autodesk.com/community/screencast/820e7c91-52af-446b-879d-bc5341859446
Constantin Stroescu
Sorry, the link was: https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revi...
They do the procedure joining two roofs, however, your answers were very helpful, thanks for your time.
Do you want to mark mine as the accepted solution as well, since it was the same as @constantin.stroescu?
How to can we create above same roof with different pitch value given to the plate height value?
How can we use above same solution with scenario for non defining slope line.
