Creating a Pattern on a Curved Wall Surface in Revit
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
asianyangman
369 Aufrufe, 2 Antworten
Hello everyone,
I'm trying to create a pattern on a curved wall surface, similar to the blue areas shown in the diagram. I've attempted several approaches, but none have achieved the desired result:
  1. Curtain Wall Family(1): I was unable to make each panel arch-shaped.
  2. Wall Splitting (2 and 3): I'm unable to calculate the precise widths along the curve.
  3. Rail Family(4): This seems to encounter similar issues as the curtain wall family.
Is it feasible to accomplish this design directly in Revit, or would I need to integrate Dynamo to make it possible?
Thank you for any advice or guidance you can provide!
2 ANTWORTEN 2
Nachricht 2 von 3
hmunsell
als Antwort auf: asianyangman
use the Curtain wall method, but after its made, swop out the panels with a Wall type.
curtain panel is flat...
the "wall" is curved.... make small mullions to show reveals between the panels.
Howard Munsell
Nachricht 3 von 3
What about a Model Surface Pattern?  Easy, breezy.
