creating a new pattern for diving a pattern based family
1 ANTWORT 1
Nachricht 1 von 2
238 Aufrufe, 1 Antwort
hey I am new to pattern based families and was wondering if it possible to make a custom pattern for dividing a conceptual mass and then applying a pattern based family to it. I have attached a snap shot of what i am trying to achieve i want the red lines (A) parallel to (1) and blue lines (B) parallel to (2) and finally the lines (c) to be vertical. Also can i make their spacing double sequentially like 2,4,8,16,32,.......
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Hard to visualize what you are describing, but I sounds like simply rotating the divided surface would work for you.  Also, there are tricks you can do with the panel itself to make it conform to a particular design.  Can you post a picture/drawing of what the as-built looks like?
