Creating a line width
I am creating a titleblock and I noticed that I was not able to make a line with a width similar to a polyline.
If I were to make this line thicker according to linewieghts in Revit, I would need a line 1.5875mm wide.  And I have tried making it, see image below.
The lines in Revit above are made with "Wide Lines".
If I try to copy a bunch of lines 1/64 apart, revit tells me its too small to see.
What else haven't I tried or thought of?
L.Maas
Revit works with line weights. Under Manage Addtional Settings you will find line styles and line weights.
Under line styles you can set the relative width of the line (usuallly a number from 1-16)
Under line weight you can set the thickness of the line corresponding to these numbers.
Louis
Please mention Revit version, especially when uploading Revit files.
Well I figured out how to make a "line" with a width I wanted.  It's really not a line at all but a solid hatched filled region.  At least now I can make my title blocks look exactly the way that our company standards intends.
