Creating a label from a sheet grouping parameter
This should be fairly simple to solve. I am still in school and trying to learn Revit. I grouped my sheets by creating some parameters and sorting sheets by prefix name with the grouping parameter first. Is there a way to have a Label reference the group parameter I assigned to the sheet? Revit labels want me to create a shared Parameter to assign to a label but I just want the parameter that I created to organize my sheets.
My sheets are organized by "Floor," "Area," and Finally "Sheet Name." I used the default revit label for sheet name but I want some that can reference my Floor and Area grouping parameters.
I can post screenshots if you need them but I hope I have provided enough info here.
You must create Shared parameters for sheet labels and add them to the project > Sheets category as well.   Non-shared parameters do not work for labels from loadable families.
