Creating a hole in a ceiling based family
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1905 Aufrufe, 4 Antworten
Hi i want to create a void type hole that is adjustable through parameters so that when my object is placed onto a ceiling it creates a hole through the center i have tried to use the void extrusions tool and the opening tool but when i place the item onto a ceiling it dose not create a hole through the middle
PLZ HELP
4 ANTWORTEN 4
Nachricht 2 von 5
martijn_pater
als Antwort auf: Anonymous
You could create a void (family) in your family without cut and select cut with voids when loaded.
(and then cut the ceiling in your project)
Nachricht 3 von 5
Draw an opening cut in the family .
Nachricht 4 von 5
martijn_pater
als Antwort auf: ToanDN
That's the way to go probably. I'm not entirely sure why that didn't work for you initially... You should be able to add parameters while drawing the sketch... I'm not sure what parameters you want to add though, in the unlikely situation that you want to make some cuts at an angle or something you could do it with a void. ^^
Nachricht 5 von 5
als Antwort auf: martijn_pater
Thanks managed to get it working now using the opening tool :grinsendes_Gesicht:
