How do you think I should layer a floor?
I was thinking,
Some type of Tile Thickness 1/8”
Plywood Sheathing 3/4”
Structure, Wood joist/Rafter 10”
Total Thickness 10 7/8”
The possibilities are endless, depending on the type of you floor and if you collaborate with another team. For example, when collaborating, you might only want to model the finish floor.
@jochia13 wrote:How do you think I should layer a floor?
I was thinking,
Hello!
After clicking to Floor, click "Edit Type", Structure "Edit..." and insert the layer you want including dimensions.
Thank you!
