Creating a drawing discipline parameter
isosa9APBT
isosa9APBT
I'm very new to Revit and I'm working on a project and I'm trying to add a drawing discipline for plumbing. For architectural is 07 - Architectural for Civil 04 - Civil and so on as you can see from the image below. This is needed fro the sheets of the Plumbing discipline. As per the second image below the first one. Once again I very new to Revit, I tried creating it using the project parameters but I must of not done it right as it doesn't show up in the pull down menu for Drawing Discipline. Any help is highly appreciated.
You can't add to In-Built Disciplines.  There are other ways you can sort Project Browser to group your custom disciplines together (e.g. by View Template).
The parameter is already created for that project, that's why the other sheets are grouped by it.  All you need to do is to select the sheet from the browser, look at the properties panel for Drawing Discipline line, click on the box to the right of it, and select 13-Mechanical for M sheet , and type in 14-Plumbing for P sheet.
Read more here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
