Creating a 3D Site Map
LiamIcely
LiamIcely
Hi I am a student, and am new to Autodesk, i was wondering what would be the best way to create an accurate 3D site model. One way that i have found would be to download the information from the OS map website, including things such as building height data and a 2D plan and then link the two together in Autocad Map 3D, however when i get to the end of the process it doesn't work, an error pops up with out any detailed information, is the any other way? Would it better to individually draw each of the nearby buildings. i have included a link the method i found using the OS data. http://digimap.edina.ac.uk/webhelp/digimapgis/index.htm#autocad/building_height_attribute/bha_in_aut... Thanks for your help Liam
Alfredo_Medina
There are more chances of getting a response to your question if you write to the Revit Architecture forum in English, at this link:
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
