Created RCP in Floor Plan
3 ANTWORTEN 3
Nachricht 1 von 4
1519 Aufrufe, 3 Antworten
Opps. I created my RCP in floor plan. Now my RCP is showing under "floor plans" in the project browser. Not a big deal, I suppose. but I'd like it to show under Ceiling Plans. Is there a way to move a floor plan view to a ceiling plan view in the project browser. I thought this would be as simple as changing the filter, but I can't figure it out.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Create a ceiling plan properly and copy paste annotation and any drafting/detail elements to it. Floor plan and ceiling plan are two separate system families so you can simply convert from.one to another.
Nachricht 3 von 4
als Antwort auf: ToanDN
What makes it special besides its upside down View Range?
Nachricht 4 von 4
Corsten.Au
als Antwort auf: barthbradley
Hi
@Anonymous Just create a new RCP, this will give solve problems which you
may encounter in the future if you continue with Floor Plan shown as RCP..
The Difference...
In RCP the Cut Plane is coincident with the bottom clip plane...
but in Plan View, the bottom clip plane is flexible..
https://forums.autodesk.com/t5/revit-mep-forum/2016-r2-view-range-dialog/td-p/5885293
Best luck
Corsten
Building Designer
