Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
like this?
Just make the Wall height equal to ridge height, complete the sweeps all the way to the top, and then Attach Top of Wall to Roof.
...and then JOIN Roof and Sweeps.
TIP: Use MULTIPLE Join. Pick Roof first and then each Sweep one by one.
post that elevation file here so we can check. thanks
If you are not success in Sweep then try Reveal, Create a wall groove profile and use as reveal in wall or create a model in place Wall void component then cut this extra part.
Thanks.
Please click "✓ Accept as Solution" on the posts that helped you, so others in the community can find them easily.
Is it possible that you can show how to do it this way? attach the file
