create void shape
3 ANTWORTEN 3
Nachricht 1 von 4
689 Aufrufe, 3 Antworten
create void shape
I want to create a void in the present geometry so i get the same result like the drawing. but i cant seem to figure out how to draw the shape in 2D. I cant seem to draw it in section because "the angle is to steep"
Tags (1)
Beschriftungen (1)
  • void
3 ANTWORTEN 3
Nachricht 2 von 4
Mohamed-Nassar
als Antwort auf: Anonymous
what about Void in place
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 3 von 4
_Vijay
@Anonymous  if you can not create a single void, if the geometry complex Crete part by part. it may lit bit slow, but it will work.
Nachricht 4 von 4
It's all about Work Planes in Revit.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
You can create a Work Plane via Naming a Reference Plane.  Then it's just a matter of setting that named RP as the Current Work Plane so that you can draw on it.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
