I have problem to create room for each level of the multistory stairs, no problem with the top level and ground level staircase, because they are different and not included in the multistory stairs.
Gelöst! Gehe zur Lösung
Gelöst von hliS658H. Gehe zur Lösung
Gelöst von mhiserZFHXS. Gehe zur Lösung
Do you have room bounding walls or room separation lines at each level?
p/s: a stair has nothing to do with the ability to place rooms.
Are the walls room bounding?
What is Room/Area Computation set to? (Area only or Area + Volume)
What are the Levels' Computation Heights?
Are the walls room bounding? - Yes, it is checked for all the walls
What is Room/Area Computation set to? (Area only or Area + Volume) - Area only
What are the Levels' Computation Heights? -from level to upper level
What's going on with the left side of that plan view? Looks like walls might not be floor to ceiling, or there might be gaps in there?
I also suspected the left wall with big opening is the culprit, so I added a room separator line there to see if it would fix the issue, although the system prompted wall and room separator overlapping, but it did fix the problem.
If you create the odd shaped openings using curtain walls with no mullions and empty system panel + edit profile to create the shape then they can cut the wall and still bound room without the need to draw room separation lines.
