Create Parts tool not on Create Tab
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2417 Aufrufe, 4 Antworten
In Revit LT 2017 I am trying to divide my floor into sections so that I can use different floor materials for a couple of rooms. I select "modify" and then select the floor. Typically there should be 4 tools in the Create Tab but I only have two tools - Create Group and Create Similar. There is no Create Parts or the other tool that are typically in the Create Tab. They aren't showing at all - not even grayed out. Any idea as to why it is not showing up?
Any help you can provide will be really appreciated!
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: Anonymous
Parts is not included in Revit LT.
Nachricht 3 von 5
FGPerraudin
hi @Anonymous,
Parts can apply for what you want to do,
But if not available in Revit LT,
What you want to use is the "split face " tool in the contextual ribbon > modify > geometry > split face (SF).
It will allow you to "cut" a part of the FACE of your floor that you will then be able to PAINT with any material using the appropriate tool
contextual ribbon > modify > geometry > paint (PT) face.
Hope this helps,
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 5
als Antwort auf: FGPerraudin
Thanks  Francois - That helps!
Nachricht 5 von 5
als Antwort auf: Alfredo_Medina
That's what I was afraid of!
