Is there a way to count the revision clouds on each sheet and include it as a read only parameter?
For instance, I want to count each of these 2 revision clouds on this sheet. Why would it only show one revision here?
Can I add a parameter to the revision cloud to read the sheet number?
Not sure if I understand. You open a sheet and you see the clouds on the sheet and the sheet number on the titleblock. What else do you need?
And what is your end goal here? What are the count of revisions clouds for?
I can export a revision cloud schedule to excel with the following parameters using DiRoots:
- Comments
- Revision Date
- Revision number
This seems like a better way to go than what I was trying to do before with a global sheet list and counting revisions.
You can use pyRevit to generate a master Revision Report including Revision Count for each sheet.
