Create Pad Like Cutouts with graded region?
3 ANTWORTEN 3
Nachricht 1 von 4
395 Aufrufe, 3 Antworten
I am trying to phase topo across threes distinct phases  graded region seems to be the right tool for this but i am having a difficult time to create pad like cutouts when placing points and is ending up being a big mess.
is there a better work around to achieve pad like cut outs with graded region?
is there a way to convert imported CAD geometry into a toposurface directly?
 or is there a better way to phase topo?
3 ANTWORTEN 3
Nachricht 2 von 4
Alfredo_Medina
als Antwort auf: Anonymous
Try with Split Surface.
Nachricht 3 von 4
als Antwort auf: Alfredo_Medina
Thank You for your suggestion, I did give split surface a try, creates two issues , one with scheduling and second when merging back into a single surface.any suggestions?
Nachricht 4 von 4
Alfredo_Medina
  1. Please define what you mean by "cut out", then.
  2. Yes, it is possible to create the topography directly from the CAD geometry.
