Create or Load new Pattern
sajad.jafarian
sajad.jafarian
Hi everyone.
Can we Creat or load new pattern in mass?
A collection of patterns is available in the Type Selector and can be applied onto a selected divided surface.But i want diffrent pattern .
what can i do?!
Thanks.
Create a new pattern type?
RDAOU
hello @sajad.jafarian
If you mean the Surface patters you apply to a devided surface/grid...(those in the image below)... You cannot. Those are not like Hatch Patterns.
Those are the bases/guide of the actual pattern that will be applied to the surface...and which you need to create separately using a pattern based family template. Which then you would load into conceptual mass or project environment and apply to the patterned grid surface. (On the image above; you may notice that I am using the simple RECTANGLE base grid and I have a Family1 applied to it...what shows on the surface will be the family1 pattern - and not the Rectangle
It is worth noting that one doesn't really need more than what is in that drop down type selector as 99% of the geometric patterns one may think of can be based on triangles; squares and hexa/pentagons.
You might wanna read this example by Zach Kron on "LINK: Making Custom Patterns" it dates back to 2010 but the rules are still the same ... they didn't change.
sajad.jafarian
Yes!
These Pattern types are limited.i want more pattern that i made!
sajad.jafarian
photo_2016-06-12_23-35-33.jpgThanks you,
Yes i mean surface pattern type! These are so limited.and there are more patten that isnt in that list! for example, see top pic. that patern is not in Patern type list!
RDAOU
@sajad.jafarian
What you have in that picture is what we create in a pattern based family template and then apply it to the grid patterns. It can be modeled using any of the grid patterns on the drop down type selector... what differs will be the bases which you build the wire frame on...ie: the trigonometry used to create that pattern.
What you see on that drop down type selector applies to the grid which  is only the wireframe or the guide for the pattern based family and not the pattern itself which you see in that picture. It doesn't just come like that....For that family which you have in the picture, it is a based on a simple _No Pattern_ rectangular grid on the cylindrical divided surface and the lights are a pattern based or adaptive family applied to this grid....I would say it (the family) is a 3 points adaptive bezierish like curve which would result  a helical strip light revolving around the tower once applied and repeated
See image below - Single Helical patteren from the _No Pattern grid...it can be doubled although it doesn't need to be. One can apply two families in opposite directions to the same grid below
EDIT: Looking at the picture closely it is not even a helix! it is a simple rectangular grid with a 3 adaptive points curve revolving horizontally around the cylinder...ie: just the grid on printscreen1 below
