Is it possible to create a new toposolid based on the old only considering excavations that have been applied to old toposolid. For example, I created a slope with excavation, I need a surface where this slope is shown with elevation points.
UNEDITED toposolid
toposolid with EXCAVATIONS
NEW toposolid need to include the excavations changes in old one.
Toposolid - not Toposurface. Big difference now. Given the fact that Topos are Solids now, what about cutting/joining two Toposolids together? Cutting/Joining removes Volume at union.
...post your topo files here and we'll take a look and see.
I don't understand what you are trying to do within this file. Can you explain please?
Maybe this is what you are after:
If so, Phasing will get you there quite easily.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-31E2EF0E-875C-4A68-958E-A06E5F2C0838
...as well as Excavation.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-21047A44-6030-49E8-B1B9-03366EA6A0C2
I think it can be solution, I correct understand that in phase 1 there is new toposolid or the floors are simply hidden? There is some tool that does that exploded toposolid? Toposolid schedule I can make as you, but I can't get a new surface without those floors. Maybe you can explain how you get Phase 1 toposolid geometry without floors.
