Create floor from excel points
3 ANTWORTEN 3
Nachricht 1 von 4
qchenTPPXV
379 Aufrufe, 3 Antworten
Greeting,
I have couple points from Excel, x, y, z values. And I  need to use those points for the to of the floor. Any ideas I can do it in Revit directly. I know that I can create a surface using these points in Civil 3D.
3 ANTWORTEN 3
Nachricht 2 von 4
jay_colcombe
als Antwort auf: qchenTPPXV
You would need to implement Dynamo for this!
https://forum.dynamobim.com/t/slab-from-survey-points/75634
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 4
Try to create a toposolid from import and choose that file (you need the export it from excel to csv or txt format).
Nachricht 4 von 4
qchenTPPXV
als Antwort auf: ToanDN
That's a good idea. What if I also have some points for the bottom of the floor. Do you think it would work?
