CREATE ENLARGED STEPS FOR STAIR (2019)
22 ANTWORTEN 22
Nachricht 1 von 23
jledgewood409
1299 Aufrufe, 22 Antworten
i would like to create a stair with the lower 3 steps to be enlarged and my railing to go to the bottom floor. as apposed to creating a model-in-place family for those 3 steps where my railing doesnt recognize. i am attaching a pdf of this stair. in the pdf i have a description of what i want to do.
22 ANTWORTEN 22
Nachricht 2 von 23
als Antwort auf: jledgewood409
Model those in-place.
Nachricht 3 von 23
jledgewood409
als Antwort auf: barthbradley
that what is what I have done. the problem is with the railing not reaching to the last step.
Nachricht 4 von 23
Create a Level at top of them and start stairs from there. Is that what you mean?
...are you modeling them under the Stair Category?
Nachricht 5 von 23
jledgewood409
I don't believe that is what I meant. if you look at the attached PDF you will see the railing only reaching the bottom of the actual stair and not to the bottom of the model-in-place family.
Nachricht 6 von 23
Edit the railing sketch and extend them.
Nachricht 7 von 23
jledgewood409
als Antwort auf: ToanDN
I am attaching a new screen shot of the highlighted railing that is extended down to the bottom of the m.i.p. family. the railing wants to flatten out and not keep the pitch (slope of the stair.
Nachricht 8 von 23
Add those steps to the actual stairs as a run by sketch then.
Nachricht 9 von 23
Nachricht 10 von 23
jledgewood409
so now the trick is for me to figure out how your railing did it and mine did not.
Nachricht 11 von 23
All I did was edit the Rail path (e.g. pulled it to first tread).
Nachricht 12 von 23
jledgewood409
it seems as though every time I tried that the railing wanted to flatten out and not carry the same slope
Nachricht 13 von 23
I was a bit tricky for me too.  It took a little finessing to get it right.
BTW: mine is a Stair by Sketch, as @ToanDN had suggested. All the treads/risers are defined in that one Sketch. The only thing I couldn't get to look right was the Supports.  The Stringers shown are modeled as In-Place Components.
Nachricht 14 von 23
jledgewood409
I am attaching a file in which the stair and rail are in for your review
Nachricht 15 von 23
Convert the Stairs to Sketch-Based and add those "enlarged" treads/risers to the existing sketch.
Nachricht 16 von 23
jledgewood409
how did you get those enlarged steps a the bottom. every time I try to create the step that is a riser for 3 to 4 sides I get a message telling me the sketch is incomplete?
Nachricht 17 von 23
Does your Stair Path extend through the entire run; first to last riser?
Nachricht 18 von 23
jledgewood409
my stair path goes the entire run. I am attaching a screen shot with the stair path highlighted. you will see the bottom 3 enlarged steps are model-in-place componentstair path.PNG
Nachricht 19 von 23
Doesn't look like it does.  Aren't those "enlarged steps" included in the sketch?  They need to be.
Nachricht 20 von 23
jledgewood409
I cannot seem to figure out how to get those last 3 steps include so that those 3 steps are essentially risers on 3 sides of the tread. similar to the image you included earlier in this dialogue
