Create enclosure
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
954 Aufrufe, 10 Antworten
Create enclosure
how can I create this kind of enclosure?
Thank's
10 ANTWORTEN 10
Nachricht 2 von 11
Revit_Whisperer
als Antwort auf: Anonymous
The easiest way is probably a curtain wall with custom mullions (I just did a rectangle) with empty panels
Nachricht 3 von 11
Railing tool.
Or, are you taking about something else in your screenshot?
Nachricht 4 von 11
Nice thing about a Rail, is this it can be hosted to and follow along the top of a Toposurface.
Nachricht 5 von 11
als Antwort auf: barthbradley
@barthbradley @Revit_Whisperer @MostafaElashmawy
with rail command I found only possibility to change material for lower current.
For top current and mullions?
.rvt file si attached.
Thank's
Nachricht 6 von 11
MostafaElashmawy
For the top rail, you should click on the top rail type then you will find the related material.
for the vertical you should edit it from the family types properties in the project browser.
check below photos.
Mostafa Elashmawy
Nachricht 7 von 11
als Antwort auf: MostafaElashmawy
@MostafaElashmawy  sorry, do not undrestand
1) For the top rail, you should click on the top rail type then you will find the related material.
==> if I click appears drop-down command. Can't put materials (I would like to have some wood as material).
2) For the vertical you should edit it from the family types properties in the project browser.
check below photos.
I find in family "palo recinzione qaudrato " ("enclosure square pole" in english) as in the pic.
But then have charge the family in the project I cound'nt find it, sorry.
Nachricht 8 von 11
MostafaElashmawy
Ok, ignore my previous message and let's do it step by step:
1-Top rail:
You can find it in Project browser>>Railing>>Top rail Type>>Rettangolare
Right click and choose Type properties.
so you can find the material . edit it.
2-Vertical:
You can find it in Project browser>>Railing>>Balaustra Rettangolare
Mostafa Elashmawy
Nachricht 9 von 11
RDAOU
If you are creating a simple horizontal/slopped fence (on a leveled surface) the curtain wall element suggested by @Revit_Whisperer  is an easy and straight forward tool.
Nachricht 10 von 11
als Antwort auf: RDAOU
@RDAOU @MostafaElashmawy
thank's very much.
Nachricht 11 von 11
Here's the file to the Rail-Topo-Pad Screenshot I post in Message #5.
Attachment: Torrenti Rail (v.2020)
