I have a building with many inclined planes in Revit (ex. the yellow plan), and I am needing to get elevations that are perpendicular to the facade planes to draw windows details, etc.
How could I create this views?
You would have to use a 3D view oriented to plane. On the view cube right click menu chose pick a plane. Choose a predefined work plane you established or pick a face to define the plane. Lock the view and tags and dims will work.
You can use the section box to control depth. You will need a custom view reference as the Elevation bug cannot reference a 3D view.
Draw a Section Mark and rotate it using the Rotate Tool. Use can control the angle precisely by placing center of Rotation. You have snapping capabilities.
