I am confused about creating pointers. I selected new, family, Annotation folder and selected Elevation Mark Pointer.rft. I see refernece lines and verbage. How do I create pointers?
Kory Skoog
CAD/BIM Manager
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
I have the pointers loaded but when I bring in the elevation tag, the pointer only shows on one side. I have 4 sides in the tag I created and I do not get check box to select which arrows I want on and off. Any help will be appreciated.
Kory Skoog
CAD/BIM Manager
Hi @kjskoog
You most probably did not assign the right parameters...but one can;t tell without the family in hand to check it for you
If you are starting from scratch and trying to experiment, I would suggest that instead of starting with a blank new template;
Do that a couple of times...once you get the hang of it; you can start from a blank template
Thanks. I opened an existing pointer and created a new fill region and did a saveas. I also did the same with the elevation tag body. Loaded the pointer into the body and then loaded the tag into our templates and it worked.
Thanks again.
Kory Skoog
CAD/BIM Manager
I can successfully edit the pointer, but I can't get the Detail Number Label to rotate properly. What property controls that in the pointer family?
I solved my problem by relocating the Detail label from the pointer family to the tag body family! Works fine.
