Create Custom Hatch Pattern
hello everyone,
i am trying to create a new hatch pattern for ceramic tiles and can't find a solution unfortunately. I tried to create a .pat file and couldnt really figure out how to make it work. Does someone have an idea/suggestion how to solve this problem? Thanks!
Pyrevit.. but you will need to create linework as it looks like you have fill patterns there.
Here is an explanation that I created to remind myself how to edit PAT files.  You may find it useful.
After some hours fighting with the .pat file, I found this piece of art that finally solved my problem:
https://forum.dynamobim.com/t/create-hatch-pattern-from-selection/24001
I only changed a couple details so i can always use it - if you are a bit familiar with dynamo that shouldn't be a problem though... Thanks!!
