Can someone please explain how I could create handrailing balustrade / posts which have the pattern shown in the attached photo.
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Hello, do you know the basic about the tool railing? or you need a class? haha
You can always make it with model in-place if you still havent learned other tools in revit ![]()
If you want to start to learn Raling, you should start here:
I've modified railing families before to create custom patterns, however I'm having trouble with this type since (I think) the profile of the balustrade is not symmetric in the plan orthogonal with the length of system.
i.e. when I created the balustrade (in the shape I want), the following message appeared and the balustrade got deleted:
An error occurred in family and was automatically resolved, but may require review by the family creator. error information: "the constraints of the sketch defining the highlighted element cannot be satisfied." error resolution: delete element(s)
See photo and Revit family attached of the balustrade I created.
Thanks.
You can use this sample to figure out how you make the railing
