I want to create a floor slab edge to show (3) 2x6 plates totaling 4 1/2". Is there a way to create this slab edge so the 2x6 plates will show in section view?
Thank you
Kory Skoog
CAD/BIM Manager
Gelöst! Gehe zur Lösung
Gelöst von kjskoog. Gehe zur Lösung
Maybe one approach would be 3 separate Profiles that stack together when applied as slab edge.
...or, 1 profile with 3 different Vertical offsets.
Actually figured it out and it wasn't too difficult. Created a new profile and insert the 2x6 nominal lumber - section detail item. Stacked 3 of them on top of each other then drew a profile line around the component to create the border. Looks good on the sections.
Kory Skoog
CAD/BIM Manager
