In scheduling of Column Material Takeoff, I would like to show the client how much material goes between different levels in the same column - that is material volume and estimated reinforcement Volume. It's ok even if I have to break the schedule level-wise, probably with filters. What's the most efficient way you would suggest?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
