Create a wall material pattern that has vert. lines and stucco pattern?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
670 Aufrufe, 3 Antworten
I am a new Revit user and need some help. I am trying to create a wall with a material that has vertical lines on it and a stucco look to it. How do I edit my material so I can have both. I only know how to do one or the other but not together.
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
David_Knight
als Antwort auf: Anonymous
Sounds like you need a custom hatch.  One that includes the stipple, and the vertical lines.
Programs like Hatchkit would be able to create one.
Nachricht 3 von 4
If the vertical lines are not to dense then you could use vertical reveals.
Nachricht 4 von 4
als Antwort auf: ToanDN
Thanks for the help guys! I actually had never used Reveal before and that worked perfectly. I really appreciate sharing that with me.
