create a view template to show only the linked model
pipapongo0909
pipapongo0909
Hi fellow Revit'ers,
I am trying to setup a view template for a 3D view that shows only one specific linked model. ( i am working on the structural model and got the MEP and several architecture models linked in).
So far i used the following workflow to setup the view to show the "Arch_model_1":
  • Create a 3D view
  • set desired link to visible through "VV"
  • select the link
  • click the "Temporay Hide/Isolate"- command ( the glasses in the "view Control bar")
  • isolate Element
  • Apply Hide/Isolate to View
After this you end up with only the selected link visible in this view
However if i cretae a view template from this view change the to another view and apply the view template my model is still visible
Any advice?
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
ramabalanv
Hi @pipapongo0909,
Instead of using "Isolate element" option, Try using Settings under Revit Links in Visibility/graphics override box and create view template. I hope this helps.
FGPerraudin
Hi @pipapongo0909,
Temporary hide / isolate or element hides cannot be integrated into templates.
I suggest that you hide every element of your 3D model section in the V/G dialog box.
Then, still within your template, select the desired revit link in the REvit Links overrides part, and set its visibilities to custom. Then, change its 3D model settings to visible.
This should work.
François
Francois-Gabriel Perraudin
BIM management and coaching
Alisder.Brown
Hey
If you are using a workshared model, simple solution is to put your links onto a workset and simply turn off all workests apart from the links within the view template.
Hope this helps
Alisder Brown
Senior BIM Coordinator
Scotland, UK
FGPerraudin
I like the solution
And you can integrate the worset display settings into your template.
Much better solution than mine.
François
pipapongo0909
thanks for the answer. All solutions were good, so thanks to everyone. I'll go with this one since the view template will not be blocked and i could apply one if needed
thanks,
Jeff Wurth
LinkedIn
