Create a step from a in place mass floor
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
665 Aufrufe, 3 Antworten
Good afternoon.
I am creating a Building using In-place mass, with three levels (Attach an image).
The problem is that there is a step in the level 2, as a result, when I create mass floors I only want to have a floor in the surface in red of the level 2, not in all the level 2 (drawing with dots).
What should I do?
Thank you very much.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Create two in-place masses.  One for Levels 1 and 3 mass floors, the other for Level 2 mass floor.
Nachricht 3 von 4
als Antwort auf: ToanDN
Thanks very much for your quickly answer.
And then, How can I join both masses? Because I use the comand join but it doest work, when I select one of them, Only one are selected and not both.
Thank you.
Nachricht 4 von 4
You don't join them  They are two separate masses.  You can still model one mass fully to add walls, curtain system, or roofs.  Just don't check Level 2 when create the mass floor. See attached 2017 file.
