@barthbradley I think the OP means a slopey level
@Anonymous why do you need a slopey level? You can
a) create a sloped floor
b) create a ramp
To create a sloped floor -
1) create a floor as you normally would
2) Select the floor
3) Click Modify Sub Elements
4) your floor will turn green with grips at each corner.
5) you can select the grips and give them an Elevation to slope the floor the way that you want.
You could hire someone with no skills to do the drafting work. That can get really messy / sloppy.
@barthbradley - rats, I neglected to put the word slopey in quotes!
"slopey"
There you go! So much better, n'est ce pas?
A sloped Level is kind of self-contradictory, don't you think? I mean, it's called a Level. If it's sloped, it isn't level. The two words are antonyms.
thank you for your reply but the attached will explain better whati mean
@Anonymous - take a look at the reply that I posted on to your new thread.
It looks like a site grade outside the building. You can use topography for it.
