hi every one!
I want to create section view perpendicular with an element in Revit, exemple in this case. I need callout a detail gutter from model. So, i have to create a section view (like work plan) like same in image attach. But i can't rotate a default section Simultaneously on both the on the plan view and Elevation view. Help me, please. Thanks all.
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Constantin Stroescu
Is this just for practice or fun?. Why are you making a cut like that for a section view? It's very strange. The Section View created would serve no value. It would just be confusing.
FYI: that is not "perpendicular".
I think he wants to annotate and put dimensions in Section View...
Constantin Stroescu
I don't think I'm seeing what you're seeing. I'm seeing "Section 3 - OP's View" in the attached PDF.
Sorry guys. I think this quarantine is frying my brain. I totally misunderstood.
hi you, i understand your way but Default section in revit can't snap on Reference Plane when Reference Plane not Vertical or Horiz.
That thing very importan with projects have angle roofs when we need callout detail them.
i think this case is problem of Revit at this time.
This is my problem. Of course i have other way is use drafting view with 2d element. But so, i have draw start from begin
maybe , this can help you....
https://knowledge.autodesk.com/community/screencast/c0151b7a-ef66-4e15-8407-c17166adcbf5
Constantin Stroescu
So you do want to do everything I did - but skewed a little more so you can produce a single Call-out view for a Gutter Detail?
You can also Orient to Plane a 3D View. Might be easier for you.
