Create a roof with 2 levels
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1682 Aufrufe, 3 Antworten
I would to crate a roof with the top surface plane ad attachment.
To do this I assembled two different roof with the second plane roof at the topest level.
There's a way to create the same with an unique roof?
Thank's
3 ANTWORTEN 3
Nachricht 2 von 4
PijPiwo
als Antwort auf: Anonymous
Not really. What you have is correct.
The other way of dealing with the main (sloped) roof is to apply cut off level instead of having two rectangular roof sketches or using vert. opening tool. The final output is the same though and you still need two roofs.
Nachricht 3 von 4
als Antwort auf: PijPiwo
I created a beam system. It view in 3d but not in view plans.
Someone can say me something?
Thank's
Nachricht 4 von 4
PijPiwo
Set your detail level to Medium or Fine. Structural framing in Coarse view displays as lines.
