create a opening in a column
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
1718 Aufrufe, 12 Antworten
It's possible to create a family that can create a opening in a column ? I don't want to use the command "opening" because i want to be able to add a tag to the opening.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
Yes. Use a face based family with a void cutting the solid in the family.
Nachricht 3 von 13
als Antwort auf: ToanDN
In order for an unattached Void in a Face-Based family to cut an element inside the host, you would need to check "Cuts with Void When Loaded".  No?
Nachricht 4 von 13
als Antwort auf: barthbradley
If you don't cut the solid with the void in the family then you do have to check that box.  If you cut it like the image I show then no need.
Nachricht 5 von 13
I just read it differently. It sounded like the family he wanted was just a Void Cut that he would load and place on the face of a column (and then cut) inside the project.
Nachricht 6 von 13
@barthbradley
You read it right. And that is how I show.  Using a face based s just a means to host the void on a face of the column more easily than a stand alone void.
Nachricht 7 von 13
Interesting. 2017.2 Unattached Void in family won't cut in Project unless "Cuts with Void When Loaded" is checked.
Nachricht 8 von 13
That is still true for all versions.  As I already said, that box needs to be checked UNLESS the void pre-cuts the host (face, wall, floor, roof, ceiling) in the family.  Unattached void family has no host, so for sure, it needs to be checked as well.
Nachricht 9 von 13
This work also with round column ?
Nachricht 10 von 13
Yes.
Nachricht 11 von 13
square too.
Nachricht 12 von 13
..octagon, pentagon, and hexagon too.
Just being silly. Smiley (Zunge)
Nachricht 13 von 13
THANK YOU Smiley (fröhlich)
