create a lookup table, parameter names are case sensitive
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
2575 Aufrufe, 11 Antworten
i want just create a plane as per the size thickness should select from table, details are attached please help
Tags (1)
11 ANTWORTEN 11
Nachricht 2 von 12
martijn_pater
als Antwort auf: Anonymous
Sure you're not looking for a type catalog?
Nachricht 3 von 12
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Here's a much better one.  Just for fun, count how many time the guy says "confusing" or some variation of the word "confusing".
https://www.youtube.com/watch?v=USqZc-VE95Y
Nachricht 4 von 12
als Antwort auf: martijn_pater
Please review my screen shot
Nachricht 5 von 12
The Lookup Value has to be in the First Column.
Nachricht 6 von 12
als Antwort auf: barthbradley
This table I created same way,
Nachricht 7 von 12
We have
L, W, thickness. So we column is thickness,  look up value L
Can you please check formula?
size_lookup(table,"thickness", 100mm,L)
Nachricht 8 von 12
Honestly, I don't know how the heck this works or what you expect it to do, but your first mistake is the first value. Should be "look up table" not "table".
Nachricht 9 von 12
martijn_pater
You should watch the video @barthbradley added, see if that helps you. Also you are using a type parameter, whereas look-up tables generally use an instance parameter. Don't know if it matters tbh, but that's from the knowledge page...
The size_lookup function is intended for instance parameters. If you want to use tabular data to define types with unique values for each type, create a type catalog
Nachricht 10 von 12
That file name is    table.csv
Nachricht 11 von 12
Yes, I know.  What's your point?
Nachricht 12 von 12
thanks dear,
the mistake which i did ,in formula i have to put parameter name of file name, now it is working.
