Hi everyone
I created 2 families. I want to create some parameters that are should be equal in these 2 families. for example a "Height" . what I want to do is that when I change "Height" parameter value of one family (in project ) the other family that contains exactly this parameter name, get exactly that value . Is it possible??!
I do not want to change values of each family separately.
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
thanks for quick answer. now i create a global parameter exactly with the name that i used in families and i set a value for it but nothing changed ,any other changes i should create?
