Creaing array that follows roof angle
2 ANTWORTEN 2
Nachricht 1 von 3
pavveETQQ3
226 Aufrufe, 2 Antworten
I created this shed that changes dimensions and everything is working fine. The shed is supposed to have metal sheets in between at a cirtain distance. I can't move the metal sheets in horizontal direction when making my array. It only moves up and down because i made them in front view to have my desired form and to be attached to the roof to follow the distance changes.
The only way the array works is if I dissoaciate it from the work plane but then it doesn't follow the roof angle or widht size.
If I draw it in another view I can't get the desired shape and it dosn't attach to the roof.
Any solutions?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: pavveETQQ3
Post the Project here.
Nachricht 3 von 3
pavveETQQ3
Here you go.
The white metal sheets need to be in the array. 600mm apart.
I did all that and used the "Lenght / 600 -1" parameter and it worked fine except they didn't change widht and angle with the roof.
