Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Point taken, @ToanDN. It's just that drawing the model lines for wall bases in interior elevations can be very wearying. I wish that Line Based Detail families were not limited to only two mouse clicks. Any ideas, O Wise One?
Just curious why would you "draw lines for wall bases in interior elevations" ? Is it not better to add the profile of the baseboard to the wall type instead? Or create the baseboard as a wall sweep?
(By the way, inthis new interface of the forum, why is the "Post" button so far from the message?. There should be another "Post" button for quick replies that don't require attachments)
@Alfredo_Medina....an attempt to bring about as simple a model as possible, while still having completely populated interior elevations.
Completely populated with what?
@ToanDN - showing as much of detail as possible, without adding more 3D complexity to the model.
