Crash when saving
Crash when saving
HUNTERKARAM8
Crash when saving
HUNTERKARAM8
having a constant issue while saving to a server. The error shown keeps popping up for almost every file I work in. If I click any of the buttons it will close instantly after saving no progress at all.  There is plenty of disk space available so am unsure of the issue.
emmanoelneri
I already had problems saving to a server and some of these things may be happening:
- Your file path in the server is too long;
- Your file name is too long or much caracteres;
- You have no memory space on the server OR computer;
- You left the computer in "sleep mode" with REvit opened;
Try to check it and see if the problems solves. If it doesn't, post here again.
