Given the problems I have with the Nvidia GTX 1060 (in this thread https://forums.autodesk.com/t5/revit-architecture-forum/whole-screen-flickers-while-rendering-with-r...) have not been resolved with the replacement card, I am looking for solutions.
- I have tried disabling hardware acceleration but it still crashes. However, disabling the card on the control panel does work. Any way to do this programatically?
- Anyone with a working GTX 1060 working with high settings on Revit 2017?
- Will a 480X Radeon work?
Rafa
Thanks for posting, can you please upload a journal file from one of those crashes?
The files are located in you local appdata folder
C:\Users\USERNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals
I'm not seeing a crash in these journals
When you say crash, are you getting kicked out of Revit and a CER window is shown? Or is the render just failing to create?
When I mean crash, it either the program closes, no warning or even windows reboots.
I got another crash with the attached journal. Getting one or the other seems to be ramdon.
OK,
the crash in this journal is the same as the one you mentioned in your other post.
DX Hardware Acceleration driver failed with Error - DXGI_ERROR_DEVICE_REMOVED
This means that your graphics card driver is crashing. Unfortunately there isn't a whole lot we can do. Do you have other systems to try this on? It really sounds like this is a problem with your PC
