Hello to all of you!
I am an architect and need to start a BIM operation. We are currently on Revit 2020 but are considering starting it on Revit 2022.
When I attempt an IFC export of our model, Revit crashes and closes (without any messages). I don't have this problem on Revit 2020 but it doesn't work on Revit 2021 either.
I guess since my colleague can generate an export without any problem, it must be a problem of my computer configuration, or hardware compatibility...
Does anyone have an idea?
Thank you in advance.
Bonjour à toutes et à tous !
Moderator note: original French message:
Je suis architecte et je dois démarrer une opération en BIM. Nous sommes actuellement sous Revit 2020 mais envisageons de la démarrer sur Revit 2022.
Lorsque je tente un export IFC de notre modèle, Revit crash et se ferme (sans aucune message). Je n'ai pas ce problème sous Revit 2020 mais cela ne fonctionne pas non-plus sous Revit 2021.
J'imagine que dans la mesure où ma collègue parviens sans problème à générer un export, il doit s'agir d'un problème de configuration de mon poste, ou de compatibilité matérielle...
Quelqu'un aurait-il une idée ?
Vous en remerciant par avance.
Moderator note: English translation added.
Sorry but this is not a solution.
I have the same problem and Revit don't even give me a chance to modify the IFC's settings.
Revit crash just few seconds after i put "Export to an IFC File".
What kind of solution can we had?
BR
I am using default options (Check image)
And like a say before, i can not setup "Extra Low" because Revit window just disappears after i click " Export to IFC File".
Thanks.
Reopen the RVT with Audit checked.
Resolve Warnings.
...see if you can Export another Project to IFC. If so, maybe a quick fix workaround would be to Clipboard Copy/Paste the Model into a brand new Project and Export it to IFC.
Thanks for the answer, but as dardilesb, i can't even access to the ifc settings in order, for example, to downgrade the level of details...
